    Mar 2011
    Paris, France
    Hello
    I'm located outside the UK and would like to download the following program:
    http://www.bbc.co.uk/iplayer/episode/b07pmyd6/inside-the-factory-series-2-4-bicycles
    Using the Chrome extension "BBC iPlayer Proxy", I can watch it in the browser, but after installing the separate BBC iPlayer Downloads application required when hitting the Download link in the page, it fails downloading the show. I attached a screenshot.
    But then, since the application runs outside the browser, I wasn't surprised since it probably hits the server directly, using my local, non-UK IP address.
    Short of taking a subscription for a VPN in the UK, does someone know of a workaround to download a BBC Two show from abroad?
    Thank you.
    Edit: The Perl-based get_iplayer mentioned in this thread didn't work either:
    c:\Program Files\get_iplayer>get_iplayer --mode=flashstd --url=http://www.bbc.co.uk/iplayer/episode/b07pmyd6/inside-the-factory-series-2-4-bicycles
    get_iplayer v2.95, Copyright (C) 2008-2010 Phil Lewis
      This program comes with ABSOLUTELY NO WARRANTY; for details use --warranty.
      This is free software, and you are welcome to redistribute it under certain
      conditions; use --conditions for details.
    INFO: Episode-only pid detected
    INFO: Trying pid: b07pmyd6 using type: tv
    INFO: Trying to stream pid using type tv
    INFO: pid not found in tv cache
    Matches:
    INFO: 1 Matching Programmes
    WARNING: No media streams found for requested programme versions and recording modes.
    WARNING: The BBC has blocked access to this programme because it has determined that you are using get_iplayer outside the UK.
    Edit: The Flash Video Downloader extension for Chrome did the trick:
    https://chrome.google.com/webstore/detail/flash-video-downloader/aiimdkdngfcipjohbjenk...ccpdbc/related
  2. Originally Posted by yetanotherlogin View Post
    Hello
    Using the Chrome extension "Watch BBC iPlayer outside UK", I can watch it in the browser, but after installing the separate BBC iPlayer Downloads application required when hitting the Download link in the page, it fails downloading the show. I attached a screenshot.
    Thank you.
    Matches:
    Sorry for bringing up an old topic. Anyone use smart dns for BBC iPlayer on smart TV?
    I want to stream it to my TV without VPN
